1 - 8 of 8 Posts
I’m trying to replace the center sprocket that drives the rear chain. I have removed the center bolt and the outside center sprocket. There’s two bolts I’ve removed for the housing for that sprocket. I can’t seem to get that housing out. Is there a clip or something I’m missing?
What year are you working on? I have a 1990 on my lift I can look at. I changed the one on that machine a couple years ago but don't remember off the top of my head what was needed.
Looks like there's 3 bolts in the chain cover 2 in front and one under the bottom.
You do know the inner sprocket has a snap ring on the shaft holding it don't you?
Thank you. In the first picture, on the left. I can’t seem to get part #3 to break free. It appears to be pushed in .
Discussion Starter #8
The bearing came off. Thanks for the help. I hate breaking out the BFH when it’s a little clip or something easy that I missed....
1 - 8 of 8 Posts
