Followed the manual, holding in the reverse
Yellow button, in neutral, turn key on. Wait for
The mile to blink, push the yellow button
Quick.
Want to see how many hrs.
I'm having no luck
To see the engine hours you don't have to go into the setup menu. Start the machine and just cycle through the display with the yellow button, I don't remember the correct order:miles, trip1,trip2, engine rpm,hours, hours till maintenance. The numbers will change as you cycle through the display. Hope this helps. Read your manual again.
Mine I can just scroll by pushing the yellow button. No magic sequence that I know of.
Good luck
He beat me to it up there.…anyways good luck.
I put on a pair of Kolpin hand protectors
With rear mirrors.
Nicked the dam wire harness and cut 1 of
The wires.
All good now.
