1 - 16 of 16 Posts
Finally hit 205 miles on my 2021 Sportsman 850. About to change front and rear differential and transmission fluid and of course oil. While I’m at it I’m going to finally grease my wheel bearings and add my fourth break. Question. Should I expect some metal on the drain magnets? Also is there anything else I should change or check out?
2017 Sportsman 850SP
You should expect some shavings on the magnets. I would check and replace your air filter and clean the prefilter. Maybe upgrade your plugs to NGK’s. Check your brake pads and all front end components since your wheels are off. Grease all zerks.
Small particle dust on the magnets is normal, large pieces of metal is not good. Thats exactly the job the magnet should be doing is taking that out of the circulating oil.
Reactions: GreenMountain71
Here is rear DIff on top and front diff on the bottom for a first change on a 21.
Perfectly normal. Wipe them clean put them back in.
Discussion Starter · #6 ·
Hers my trans
Front differential (only time it’s been in 4wd is to load in back of truck)
Rear
Your front diff turns when the ATV is moving
Hers my trans
Rear
That exactly how mine was , rear was way more fine fine shavings .
everything looks as it should!...good job
Finally got the 4th break on! New NGK plugs! Ready for tomorrow
The warning stickers are funny . What does the sticker on the back fender say ? The one with the lady ...?...
So I know you most likely already know your torque requirements , let us know if you need any numbers .
looks awesome
1 - 16 of 16 Posts
