Can I change just the starter solenoid by removing the starter or do i have to remove the flywheel to gain access. Or is there a whole other procedure in itself....
First off welcome to the board!
Starter soleniod should be mounted up by the battery box. Not like an automotive starter. Part number for the soleniod is 3085521 which subs to 4011335. Should cost you right around 35 bucks.
