Do you prefer a good bone stock atv, or one that you can easily mod?
  • Bone Stock
    Votes: 3 20.0%
  • MOD IT!
    Votes: 7 46.7%
  • good MODDED atv!
    Votes: 4 26.7%
  • cheap bone stock atv
    Votes: 1 6.7%
hello, ive got an 05 sportsman 800 and i have recently slapped some 30''X9"X14" silverbacks on her and have had some rubbing issues during bumpy turns, i have lifted the front 1.5" and have shaved off those little ''fins'' on the inside of the fender, but i still get a little rub action in there, and would like some advice on how to solve that without moving the wheels forward, thanks!
Define cheap!?!?! You can get a RDC 2" lift front and rear for about $140.00 I have one installed and run 28"s and have clearance for days. You could always go bigger than 2" but that involves replacing axels and eveything else. GL.
decided to revive this post, i mean cheap as in, as close to free as possible, but i will entertain any good ideas
If I'm not mistaken, you could use a 2" spring spacer, put a set of ranger springs on it, or as istalvey said put a bigger lift on your bike.
i have already lowered the shock towers one inch and that is as far as i can lift the bike without having to replace the axles. so lifting isnt an option, i really dont want to cut the control arms and move the tires forward, so im looking for ideas that dont involve lifting the bike or cutting the arms
