never realized that most atv's dont have reverse lights, WTH! i for one like to see where i am going, forwards and in reverse lol. i found these on ebay daily deals for like $8, its a 12v 10watt led flood light. figured for about $10 why not try them.
i couldn't really find a non-permanent place to mount them, so i bent some sheet metal and tig'ed it to the mount on the light. i drilled the sheet metal so i could use the factor bolt on the back. for power i ran wire to the headlight pod and used the extra accessory power tap and a waterproof switch, this pulls less then an amp.
since its a very wide beam it doesn't seem bright, but it covers a large area. so far its worked great plowing so i don't run stuff over and when i am backing in to the garage.
Awesome! I need the same
ya its easy and temporary, i didn't have to weld the bracket but it gave me a reason to play with the tig welder lol drilling two holes in the sheet metal would do the same thing so anyone can do it no special tools required.
