1 - 2 of 2 Posts
sportsman 700 entire bike part bike. most parts will work on the 500,600,700, or 800 i am located in Shreveport, LA. i will ship the parts to you if you pay the shipping. please respond to the forum, call or text me at 318 469 0628, or email me at [email protected] for more info. can send pictures by text or email. you can either buy these parts off of it or buy the whole parts bike
original bike is a 2004 polaris 700 fuel injection
$ Part
200 frame
20 ripped seat needs to be recovered
50 rack front
50 rack rear
20 back rack mount
50 gas tank
20 plastic pod (red & black)
100 fenders front (black)
100 fenders rear (black)
75 floor boards each ($125 for both)
250 diff front
250 diff rear
45 head light high beam
25 head lights low beam each (50)
25 tail lights each
50 wire harness*
50 ignition*
50 starter
50 run over ride & lights switch
50 thumb throttle and 4X4 switch
50 voltage regulator
100 cdi box
100 speedo
75 throttle body
45 intake box and boot and filter
35 brake caliper each (140)
25 hub each
25 brake disk
25 handle bars
35 steering stem
50 stock exhaust
300 transmission
500 complete motor that needs top end rebuilt (they normally cost $1200+ in the same condition)
50 axles each ($150 for all of 4)
50 front drive shaft
50 rear drive shaft
15 a arms each ($50 for all 4)
30 suspension each (100 for all 4)
25 foot and hand brake lever
Is the bike still in one piece? Any pics?
1999 Sportsman 509
Wiseco 93mm forged piston
Moose top end gaskets
CRU aftermarket HO camshaft
new carb diaphragm and block
Summit water temp gauge
EPI clutch rebuild
custom spacers on both clutch springs
runnin Mobil 1 0W-40
1 - 2 of 2 Posts
