I have the check engine light on but the motor is cold? Could the ECM cause this problem?? I know there is a recall but want to check to see if anyone else has had the same problem. Thnks
Administrator
Hi Brad, Welcome!
When the quad warms up does the check engine light go out?
caution hot light? or other light? hot light might just be your rad pluged solid, you should beable to see through the fins if you look stright at it!
You didn't say what you are working on. I take it you mean you have a NOT and check engine light. On my quad, I think the fan function is controlled by the PDM (ECM) and the HOT warning is controlled by the ECU...but I could be wrong. I would start with checking the sensors.
Also, I think if there is an open in your fan circuit, you will get the indications you have.
Sean
