1 - 2 of 2 Posts
Have the following problem:
If I have frequent stop and go in city traffic, the check engine light comes on and I can give no more gas.
I have to come to a complete standstill and increase the speed until the indicator light goes off.
Only then I can start again driving!
My dealer has checked the following things:
-Read out fault memory (No mistakes!)
-Updating the controller with the latest firmware!
-Error in the throttle cable fixed (error at full throttle in potentiometer!)
-Review of the 2 sensors that usually cause this error! (No fault!)
Error is still present.
Thanks for your help!
Discussion Starter #2
Problem solved!
Problem is solved!
Troublemaker were the TPI-Sensor.
Must have 4,6 V, had 5,7 V.
New Sensor --> no more problems! :)
1 - 2 of 2 Posts
