I have a 07 700 Sportsman and the Check Engine Light started coming on, but not long after that the Wrench Icon started coming on too. I checked the codes on it and it came up (46) & (41). I know that these are sensors, but where are they located and how would I fix this on a LOW budget????? I would appreciate any help, Thanks Russell700 :feedback:
I have the manual for the 08 700 so if it is the same then these two codes are from the same sensor the Temperature/ barometer sensor which is located on the intake tube.
This should be easy to change if you have to do it yourself.
Before changing it I would locate it and unplug the sensor and check over the wiring and plug real well...... then disconnect the battery for 15 min and reconnect the sensor and battery...... then run it and see if the codes will reappear.
