I have a 2012 XP 850 HO Touring LE w/ 6000 kms on it
I have changed the throttle cable
adjusted the throttle cable to 2 mm
replaced the TPS and the wiring harness
adjusted the throttle cable 2.5 mm
plug wires
plugs
and i still get check engine code once and awhile usually bout 4 or 5 times
when out on a 100 km tour.
it will go into limp mode and show the code, if i let the atv roll almost to a stop the code will clear itself and you can just drive away.
if i am travelling at 80 kph i just turn the key off and back on to reset the code.
anywheres else i can throw some money ???
code is always stuck throttle :motz:
plug wires
plugs
