1 - 12 of 12 Posts
Took my new Sportsman out for a 39 mile trail ride last week, and got it good and dirty!
139574
So, finally purchased an electric power washer today...
139572
Got it sort of "clean" at the car wash on the way home the day of the ride, but not really clean. Today, I pulled it up on some mechanic ramps and went to work. Now it's clean!
139573
Just a tip with pressure washers. Always, always have water. When they stop getting water, because the hose is kinked, or for a gas, you started it before turning the water on, the pumps become junk.
Also, wear some sort of eye protection!
I would like to offer my opinion also-please remember that a pressure washer will force water into places it couldn’t go without pressure. When I raced motor cross, all the bike manufacturers stated “do not use a pressure washer to clean” I’d be careful and lube the hell out of it after pressure washing.
Yup, gotta keep your eyes covered!
Just got a foam cannon to use with it. Much easier and more effective than just my garden hose with a sprayer.
Be careful of forcing water past the bearings and seals. Getting water into the front or rear diff by blasting it into and past the bearing and seals will be worse then a dirty machine.
One more tip. When you are done for in the fall, use some of the pressure washer anti-freeze or put the washer where it can't freeze. Water remains inside the pump and when frozen, will not be good.
Discussion Starter #9 (Edited)
140020
140039
Gotta say, this foam cannon is great. And thanks for all the warning on getting water in places there shouldn't be. Helpful info.
Discussion Starter #11
Man, it came that way stock. I had heard about heat issues on Sportsman models, but have not had any issues with it at all.
1 - 12 of 12 Posts
