1 - 14 of 14 Posts
Looks like the line on mine from the radiator. Do you have one already hooked up with green antifreeze showing in it?
Not too sure then Maybe its just an extra piece of tubing that got left in the engine compartment. Weh i get home in about an hour I'll look at my unit and see if there is a second tube anywhere. I'll post again if i find something.
Well the only two are the ones going to the radiator over flow that I can find. Not sure if what you have is one of those or just an extra hose? Wish i could be more help.
Is there a vent tube coming off of the side of the battery? A lot of them come off since there is nothing keeping it clamped to the battery. Mine on my 500 comes off all the time so i now zip tied it on.
if your battery is not a AGM..that may be the vert tube from it like gr8wte said....they are prone to fall off..mine was long like that till I got a AGM....i put it in my other ATV an just put a tiny drop of super glue on it..very tiny...not to block the vent...check yours..you dont want acid dripping on the frame parts
It looks like the battery vent tube
Too large for the battery vent. Just be sure there is a vent tube coming from your transmission, front diff, and coolant overflow. All three should run up under the front where the top steering stem bushing is.
1 - 14 of 14 Posts
