1 - 1 of 1 Posts
I am fixing my buddies 2006 Sportsman 500 HO that is clicking in the transmission. His front drive shaft stripped out, so he removed it. When he drove the quad without the shaft it would click when turning left or backing up. I have removed the transmission and found both rear drive shafts and the internal transmission splines are worn. We are replacing the snorkle shaft and 59 t sprocket and both rear side axles.
When I checked my quad (same quad '06 HO) I noticed the inner CV's are also loose on the transmision and I only have 250 hrs on the quad. Is this common?
1 - 1 of 1 Posts
