How do I go about setting the clock on my 2013 850xp eps? Any help would be very much appreciated.
Owner's Manual?
Thanks.... Didn't know that.incidentally, for those that don't know, if your machine is off and you just want to check the time.. Hit the mode button and the time will appear for 5 or 10 seconds..
From the 2012 owners manualInstrument Cluster
--Digital/Analog Gauge
---Rider Information Center
----Clock Mode
Tip: The clock must be reset any time the battery has been disconnected or discharged.
1. Turn the key to the ON position. Use the MODE button to toggle to
the odometer display.
2. Press and hold the MODE button until the hour segment flashes.
Release the button.
3. With the segment flashing, tap the MODE button to advance to the
desired setting.
4. Press and hold the MODE button until the next segment flashes.
Release the button.
5. Repeat steps 3-4 twice to set the 10-minute and 1-minute segments.
After completing the 1-minute segment, step 4 will save the new
settings and exit the clock mode.
6. Turn the key to the OFF position.
OK I tried this and it didn't work. Held it for a few seconds and nothing happened.Thanks.... Didn't know that.incidentally, for those that don't know, if your machine is off and you just want to check the time.. Hit the mode button and the time will appear for 5 or 10 seconds..
:damnit:Well if it won't give you the time of day maybe it's mad it you.
Give it a bath, blow in it's ear....
