Hey folks, so I picked up above machine and guy said it just needed an exhaust and a carb clean. No big deal, I managed to find an exhaust from an 800 and bolted it on. Cleaned the car thoroughly(not my first time). Bike starts and idles fine. Put new plugs and after a short run I pulled them...
So I’m ordering new springs all around for ‘17 570. I watched a video on YouTube where guy is changing spring with strut still connected at bottom and he is just pushing spring down and threading top nut on by hand. Is it really that easy or do you have to compress spring another way?
Hi All,
Recently acquired a 2000 / 2001 Scrambler 400 2x4 from late uncle. Runs well but has seen limited activity in it's life. Used few times (<10 times) and mostly sat idle in a shed with fuel lines off. Looking to perform general maintenance on it since I'm assuming it's been a while. New...
I,m new here hoping for some answers. My 06 Ranger 700EFI will not accelerate. Idle is ok but rough. Plugs were fouled black but new plugs did not help TPS was replace five years ago. Injectors were checked and cleaned a year ago. Fuel pressure is about 36PSI and holds constant on acceleration...
