Has anyone used silicone instead of the gasket for the clutch cover. Lost the gasket and the dealer closes in an hour
Ok what kind of silicone and how hard would it be to remove cover if belt grenades on trail??
I think silicone would be a pain to use because of cleaning it off every time you take the cover off. I have heard of people using it though. I also read someone using a wax ring for a toilet. I can't see why it wouldn't work and I would think it would come off a little easier. I was going to try that if the factory gasket leaked on me.
What I did was run a thick bead of rtv where the gasket would have been and let it dry for about six hours than installed the cover. I was trying to accomplish a more permanent gasket. Ill find out how well it works next time I go through some water.
I used silicone on my cover and my backing plate. It stays dry as a bone and my belt drive stays under water.
