Which spacer should I use on a sportsman 500 ho that rides trails and mud a lot. The low rpm one or the higher ones. I got the kit from qsc.
For a lot of mud riding you don't want to high of an engagement. It's very hard on the driveline and axles. Try it with the thin shim and see what you think. Not hard to change it up if you don't like it.
Thin shim works great.
Discussion Starter · #4 ·
Thanks I got it Monday maybe I can put it on in the next couple of days.
