1 - 2 of 2 Posts
2011 Polaris sportsman 400ho. In high gear going around 20mph in at around 6500rpm then it feels like the belt grabs then I have normal high gear. Replaced the belt and have the same issue. At idle in low gear/reverse, if you give the bike a little push the secondary will engage and it'll drive a little bit. Anyone know why it could be causing these issues?
Both clutches need the up to this date not done routine maintenance performed on them
1 - 2 of 2 Posts
