1 - 20 of 99 Posts
I'm new to this Bike, And the last one i owned was a yamaha 350 20+ years ago. I have a 2017 XP 1000 ( Bought Used) now has about 62 hours and almost 600 miles on it. I have no issues shifting it, sometimes might get binded that causes me to maybe rock it back and forth, but no issues. I guess I'm not sure on the amount of force that it should take to shift. sometimes, it's like butter, sometimes I have to apply more force, but nothing that has me saying "Damn, I can't shift this thing.
This weekend my daughter wanted to put around at like 3 MPH. She could not shift to save her life. Is it the size of the machine that makes it it tougher to shift, or should i look into and aftermarket clutch kit?
Looking for thoughts or input, maybe I'm looking to deep into something that is normal. :)
One-Way beraing in the Primary Clutch is binding up.
Old One-Way
Land vehicle All-terrain vehicle Vehicle Automotive tire Tire
New OneWay
Wheel Automotive tire Tire Metalworking Machine tool
#2 in parts diagram
Product Font Auto part Parallel Diagram
Reactions: Modern44
Old One-Way
New OneWay
#2 in parts diagram
Is this common to go so fast if this is the case? I am not in the area of thinking i may get stuck, but more curious. I've seen videos of just swapping this bearing out and it seems straight forward. If i do this, would it benefit me to put in an upgraded kit? Kill two birds with one stone I guess
That picture is my bearing from a 2019 850 sp Premium at 855 miles
  • Wow
Reactions: Doc8404
If it shifts easy with the engine shut off, and hard when running its the One-Way bearing
You can put an upgrade clutch kit in at anytime. The Primary clutch can stay on the ATV to do this. The secondary clutch has to be removed to change the springs. Also would suggest to change the square pucks in the secondary to rollers from HunterWorks
Wood Rectangle Auto part Hardwood Metal
Automotive tire Wheel Alloy wheel Rim Gas
Reactions: crazyflyboy30
Discussion Starter · #10 ·
If it shifts easy with the engine shut off, and hard when running its the One_-Way bearing
Makes 100% sense! Yea, so i can shift without thinking I'm in an arm wrestling competition when its off, so i guess that's a good thing. Maybe my daughter is to fragile and weak still is the problem lol. But i do think soon that bearing could be an issue. So the spring in the clutch has nothing to do with the shifting, not more that that one way bearing then?
Discussion Starter · #11 ·
What benefit do the rollers add compared to the square pucks?
Whats hgapening is the Primary beraing is shot and the belt continues to turn the secondary and thats what makes the hard shifting. Just pull the belt cover, start it, it should look like this when in Netural or Park. Primary spinning, secondary stationary
Wheel Automotive tire Automotive lighting Motorcycle Motor vehicle
2 benifets
Your secondary sheeves will wear out quickly and then you throw the secondary clutch out. Them pucks are very hard on the clutch surface they contact.
Up and down shifting is very smooth
Automotive lighting Automotive tire Hood Motor vehicle Automotive design
Automotive wheel system Automotive tire Gas Rim Auto part
Just so you understand, A clutch kit has nothing to do with you shifting gears. A clutch kit changes the RPM's that the clutches engauge/grab ahold of the belt and take off.
Two compleatly different functions.
Reactions: Modern44
Look at the wear in the clutch metal on post #15, this is at 850 miles. The pucks slide in the metal, the rollers roll.
Reactions: Modern44
Discussion Starter · #20 ·
I understand now, the whole time I thought they played hand and hand. How, I dont know...thats why I asked. I have zero shame in asking a question lol. Thanks for putting it politely FDP!
1 - 20 of 99 Posts
