I have a 2012 850. Just installed a looney tuned and uni. Should be gettin a PCV and auto tune by the end of the month. What clutch kit do y'all recommend, air dam or dalton? I am running 27 inch black diamonds
Most here use QSC. Airdam's are regarded as the premium but they are a lot of money and slow delivery. Look for Ridinagain around here. He is a Quad Shops Custom dealer.
Thanks for the reference! :beerchug: I just worked out a deal with Dobeck Performance on becoming a dealer for them too. Will have a great supply of fuel controllers and other great stuff very soon. Comparable to the Dynotech stuff, but easier to use and adjust and cheaper too.
QSC...I drive by their facility every weekend and I picked my kit up from Adam. He is a rider, he knows his clutching. You will get a good product with him.
I second that. I spoke with Adam and he recommended a clutch kit for my specific application. Took my first ride with the new QSC clutch kit this weekend and am very satisfied.
If you've got the coin, air dam all the way!
Thavandy, on my old 2012 850 touring the Uni filter turned the spark plug electrodes white. Do a full throttle run and pull them. I took the Uni out so I was not running lean. Let us know the condition of your plugs. If they don't turn white you probably are safe. Just letting you know so you make sure the engine is not lean.
