Ok who has them installed on the scrambler 850 and what kind of improvements have you noticed. Looking for faster out of the corner/ out of the hole.
I've been reading a lot about clutches and kits and always read the "faster backshift" part and, frankly, I don't want faster backshift. I race my Scrambler and it gets downright scary on those steep downhills. If I let off the throttle all the way the back tires pull so hard to slow me down that it's sometimes uncontrollable and always hair-raising. I definitely have to be on my game for the downhills, which is fine on the first lap, but as the race wears on I get tired and can loose focus and throttle control.Will give big gains on bottom and mid range pull, faster backsift to keep power on tap coming out of the corners.
I am not on here to argue with you, I know you are selling a product and need to promote it, but the QSC kit is not going to be better than airdam. Heck, I run a QSC kit because it is the best bolt on kit out there in my opinion, and is reasonably priced. That being said, if you want the most out of your machine, airdam is the way to go. There are multiple stages of machining and tuning that you can get specific for your atv. You will have your gains in low and mid, and yes, even on the top end. So, in closing, if you are a trail rider, whether it be sand, mud, rocks, hardpack, I agree that QSC will get the job done. If you have competitive racing in mind, then Airdam is the way to go.Everyone I've sold one to loves them. Airdam, Yeah.... Not needed. Unless you have a can am. Then.... well, still not needed. The QSC stuff is cheaper, and better IMO. Complete clutch kit for a 850 scrambler is a set of weights, and springs for both clutches. Will give big gains on bottom and mid range pull, faster backsift to keep power on tap coming out of the corners. Requires less throttle to get the tires spinning in the mud and goo, so less chance of snapping an axle. 2-3mph loss on top end is the only disadvantage. Takes out the 0-20 waiting for the rubber band to stretch feeling, smooths out engagement-especially in reverse, pulls wheelies in high gear easily, and only costs $219 plus shipping. In stock and ready to ship after thanksgiving.
The Polaris primary is light years ahead of the airdam design in efficiency, durability, and ease of tuning. You couldn't give ma an airdam to run on a Polaris. I'd take it over a can am primary though.
I really don't want to start an argument ether, but people need the facts. Airdam makes a decent product, but not the best. It is a 60 year old clutch design that requires a bunch of machining to make it work better than the stock Polaris P85. QSC primarys for can am are a modified team/p85 to fit the shorter housing of the can am clutch covers. The towers are shortened and custom cover because of it. Guess what every one of the top finishers at the mud nationals is running for clutching, including the factory teams. QSC. Only about 2% of the race teams run anything else. Unfortunately that means that almost all the top competitors are on Can Ams, not polaris. :str:I am not on here to argue with you, I know you are selling a product and need to promote it, but the QSC kit is not going to be better than airdam. Heck, I run a QSC kit because it is the best bolt on kit out there in my opinion, and is reasonably priced. That being said, if you want the most out of your machine, airdam is the way to go. There are multiple stages of machining and tuning that you can get specific for your atv. You will have your gains in low and mid, and yes, even on the top end. So, in closing, if you are a trail rider, whether it be sand, mud, rocks, hardpack, I agree that QSC will get the job done. If you have competitive racing in mind, then Airdam is the way to go.Everyone I've sold one to loves them. Airdam, Yeah.... Not needed. Unless you have a can am. Then.... well, still not needed. The QSC stuff is cheaper, and better IMO. Complete clutch kit for a 850 scrambler is a set of weights, and springs for both clutches. Will give big gains on bottom and mid range pull, faster backsift to keep power on tap coming out of the corners. Requires less throttle to get the tires spinning in the mud and goo, so less chance of snapping an axle. 2-3mph loss on top end is the only disadvantage. Takes out the 0-20 waiting for the rubber band to stretch feeling, smooths out engagement-especially in reverse, pulls wheelies in high gear easily, and only costs $219 plus shipping. In stock and ready to ship after thanksgiving.
Ok, thanks for the info. As I said, I'm new to the CVT world. Light and snappy is the way I want it so I can raise the frontend over obstacles even when going 15-20 mph. I have no problem with the efficiency of the clutching now, it is very smooth an linear, just looking for more snap. I'm sure you can taylor a kit for me. I plan to give you a call after I get through the Christmas season and get to January when I'll start prepping my quad for next season. Thanks for your help.Louisanaxcracer, what you're probably experiencing is the EBS, not the backshift of the clutches. That is one of the things that many don't like about having EBS, but the majority do like it for the same reasons. However, you could try the stock secondary spring but it will shift out even faster with the QSC weights in the primary since they grab harder in the low and mid. That may cause it to feel loaded down instead of light and snappy.
