Hey guys i am having trouble with my 2002 500 Ho sportsman. The clutch will not completely disengage and keeps enough grip to move it and makes it extremely hard to shift into gear. I took it apart, and the part that the belt rides on in the clutch free spins and moves a little left and right. If I take and pull the belt by hand to the left( Away from the engine) it works fine but as soon as you give it gas it moves back over and wont fully let go. How do I fix this ? Any ideas?
Is the center piece suppose to have play left to right on the clutch? also i pulled the drive pully off and the gap the belt rides on closed and will not open back up. is it spring loaded or what? is the fact that the clutch had play in the center the problem?
