I took off my primary clutch today and the main bolt that holds the primary clutch was bent what would cause that so I ordered a new bolt don't think it would cause the clutch to be off balance thanks for any input
Over torqued could do it. Lucky it didn't break. They always seem to do it right at the start of the threads deep into the crank end. Won't affect clutch balance.
Thanks for the reply it was done from factory was putting in your clutch kit pulled primary and dropped the bolt and noticed it wobble as it rolled on the floor wasn't sure if it would affect clutch balance put a new bolt in
