I have a question about swapping a primary EBS clutch for a non EBS clutch.
2005 sportsman 500 HO EBS to a 2009 Sportsman 500 non EBS clutch.
Can I simply change the belt to a non EBS belt and leave the driven clutch alone, or do I need to change the driven clutch to a non EBS clutch ?
With all the snow this winter I wore out the original EBS primary clutch plowing.
Thanks much in advance, new to forum.
Bluto
Welcome to the board!
I put the used 2009 clutch on with the new belt ( gates number 20g4022 ) and very difficult to engage into gear.
Belt seems to tight, so put old belt on 3211095 Polaris original and seems to work OK, should I go with another stock belt ?
or is it maybe an alignment problem? work good with old belt.
I did change to a non ebs primary clutch.
Thanks in advance.
Discussion Starter · #6 ·
Just spoke with Ryan from RVS, Real nice guy and very knowledgeable.
Need to ad a .030 " shim between the sheaves on the secondary clutch for proper belt deflection.
Thanks again Ryan.
Kurt
