what is the next heaver spring for a 02 700.my clutch is dragging on the belt making it hard to shift at times. I have to turn it off to shift some times idles is set at 1150. (ebs)
Make sure the belt is centered on the primary when it is running/idling. If it is dragging on one of the sheaves, that can cause the problem. 11 year old quad...might just be time for a rebuild.
Sean
Discussion Starter · #4 · (Edited)
ok i'll try centering it , maybe that's it I had the engine out when I rebult it then after I had the problem. thanks for the help. but I could use a heaver spring because the over size tires and snow plowing
