There are differences in the clutches for 2018 within the various models offered.
A 2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/F57B8) used clutch part # 1323063 while a 2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/F57B8) used clutch part # 1323167
However, clutch 1323167 was used on the following models:
2014 SPORTSMAN 570 EFI (A14MH57AA/AC/AD) - Drive Train, Primary Clutch
2014 SPORTSMAN 570 EFI EPS (A14MH5EAA/EAC/EAJ) - Drive Train, Primary Clutch
2014 SPORTSMAN 570 EFI EPS FOREST (A14MH5EFJ/EFK) - Drive Train, Primary Clutch
2014 SPORTSMAN 570 EFI HD (A14MH57TD) - Drive Train, Primary Clutch
2014 SPORTSMAN 570 FOREST (A14MH57FA/FJ) - Drive Train, Primary Clutch
2015 570 EFI/EPS FOREST TRACTOR (A15SET57CA/S57CJ/CA) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI (A15SEA57AA/AC/AD/LD) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI EPS FOREST QUAD (A15SEB57CA/CJ/SEC57CJ/CA) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI EPS MD (A15SEE57HJ/HA) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI MD (A15SEA57HA) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI TOURING EU (A15SDA57FH) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 HD (A15SEH57AD) - Drive Train, Primary Clutch
2015 SPORTSMAN TOURING 570 EFI MD (A15SDA57HH/HA) - Drive Train, Primary Clutch
2015 SPORTSMAN TOURING 570 EFI/EPS (A15SDA57AA/LJ/E57AJ) - Drive Train, Primary Clutch
2016 450 HO 2X4 MD (A16SAA57N1) - Drive Train, Primary Clutch
2016 SPORTSMAN 450 HO (A16SEA45A1/A5/SEE45A1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 EFI (A16SEA57A1/3/7/8/9/L3/L7/L8/E57A1/3/5/7/9/D57A2) - Drive Train, Primary Clutch A16sea57a1/3/7/8/9/L3/L7/L8
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/E57A1/2/5/7/9) - Drive Train, Primary Clutch A16sea57a1/7/8/9/L7
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/L7/E57A1/5/7/9) - Drive Train, Primary Clutch A16sea57a1/7/8/9/L7
2016 SPORTSMAN 570 EFI HD (A16SEH57A7) - Drive Train, Primary Clutch
2016 SPORTSMAN 570/450 EFI MD (A16SEA57N1/N7/E57N1/E57N2/BA57N1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570/450 EPS QUAD (A16SEB57C1/C2/SEC57C1/C2/CL/SBB57C1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570/450 EPS QUAD (A16SEB57C1/C2/SEC57C1/C2/SBB57C1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570/450 EPS ZUG (A16SES57F1/F2/SBT57F1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570/450 TRACTOR (A16SET57C1/C7/SES57C1/C2/SBT57C1) - Drive Train, Primary Clutch
2016 SPORTSMAN TOURING 570 EFI EPS MD (A16SDA57N2/E57N2) - Drive Train, Primary Clutch A16sda57n2
2016 SPORTSMAN TOURING 570 EFI/EPS (A16SDA57A1/L2/E57A2) - Drive Train, Primary Clutch
2017 450 FARMHAND HD 2X4 (A17SAH50A5) - Drive Train, Primary Clutch
2017 SPORTSMAN 450 HO (A17SEA50A1/A5/SEE50A1/SEG50A4) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 EFI (A17SEA57A1/5/7/9/L7/L8/E57A1/7/9/F57A4) - Drive Train, Primary Clutch A17sea57a1/5/7/9/L7/L8
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/8/9/L7/L8/E57A1/7/9/F57A4) - Drive Train, Primary Clutch A17sea57a1/7/9/L7/L8
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/9/L7/L8/E57A1/7/9/F57A4) - Drive Train, Primary Clutch A17sea57a1/7/9/L7/L8
2017 SPORTSMAN 570 EFI HD (A17SEH57A7) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 EPS EU (A17SEA57F1/SEE57F1/F2/FL) - Drive Train, Primary Clutch A17sea57f1/See57f1/F2
2017 SPORTSMAN 570 EPS ZUG (A17SES57F1/F2/FL/SET57F1) - Drive Train, Primary Clutch A17ses57f1/F2/Set57f1
2017 SPORTSMAN 570 TRACTOR (A17SES57C1/C2/C7/CL/E1/E2/E7/EL/SET57C1/C2/E1/E2) - Drive Train, Primary Clutch A17ses57c1/C2/C7/E1/E2/E7/Set57c1/C2/E1/E2
2017 SPORTSMAN 570/450 EFI MD (A17SEA57N1/EE57N1/NL) - Drive Train, Primary Clutch A17sea57n1/Ee57n1
2017 SPORTSMAN TOURING 570 EFI/EPS (A17SDA57A1/E57A2/E57L2) - Drive Train, Primary Clutch A17sda57a1/L2/E57a2
2017 SPORTSMAN TOURING 570 EFI/EPS (A17SDA57A1/L2/E57A2) - Drive Train, Primary Clutch
2018 450 SPORTSMAN HD 2X4 (A18SAA50N5) - Drive Train, Primary Clutch
2018 SPORTSMAN 450 HO (A18SEA50B1/B5/SEE50B5/B8/SEG50B8) - Drive Train, Primary Clutch
2018 SPORTSMAN 450 HO (A18SEA50B1/B5/SEE50B5/SEG50B8) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/BK/F57B8) - Drive Train, Primary Clutch A18sea57b1/7/9/L2/L5/L7
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/F57B8) - Drive Train, Primary Clutch A18sea57b1/7/9/L2/L5/L7
2018 SPORTSMAN 570 EPS EU (A18SEA57F1/SEE57F1/7) - Drive Train, Primary Clutch A18sea57f1
2018 SPORTSMAN 570 EPS TRACTOR (A18SES57C1/C2/C5/C7/E1/E5/E7/P57C1/T57C1/C7/E1/E7) - Drive Train, Primary Clutch A18set57c1/C7/E1/E7/P57c1
2018 SPORTSMAN 570 EPS TRACTOR (A18SES57C1/C2/C5/C7/E1/E5/E7/T57C1/C7/E1/E7) - Drive Train, Primary Clutch A18set57c1/C7/E1/E7
2018 SPORTSMAN 570 EPS ZUG (A18SES57F1/F7/SET57F1) - Drive Train, Primary Clutch A18set57f1
2018 SPORTSMAN 570 TOURING EPS EU (A18SDA57F1/SDE57F1) - Drive Train, Primary Clutch A18sda57f1
2018 SPORTSMAN TOURING 570 EFI/EPS (A18SDA57B7/L7/E57B5) - Drive Train, Primary Clutch
2018 SPORTSMAN TOURING 570 EFI/EPS (A18SDA57B7/L7/E57B5/D57LU) - Drive Train, Primary Clutch
and part # 1323063 was used on these models:
2014 SPORTSMAN 570 EFI UTE HD EPS (A14MX5ETH) - Drive Train, Primary Clutch
2014 SPORTSMAN TOURING 570 EFI (A14DH57AA/AJ) - Drive Train, Primary Clutch
2014 SPORTSMAN TOURING 570 EFI INTL (A14DH57FJ) - Drive Train, Primary Clutch
2015 570 TR PRM PS MD (A15SJE57HI) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI EPS (A15SEE57AA/AC/AJ) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI UTE HD (A15SUH57AH) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI X2 EPS (A15SWE57AA/AD) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 EFI X2 EPS EUROPE (A15SWE57FA) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 SP (A15SHD57AC/E57AS/AM/L57AK) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 SP EPS, QUAD (A15SHC57CS) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 SP EPS, TRACTOR (A15SHS57CS) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 SP MD (A15SHE57HS) - Drive Train, Primary Clutch
2015 SPORTSMAN 570 SP TOURING (A15SJE57AS/AV) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 EFI (A16SEA57A1/3/7/8/9/L3/L7/L8/E57A1/3/5/7/9/D57A2) - Drive Train, Primary Clutch A16see57a1/3/5/7/9/D57a2
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/E57A1/2/5/7/9) - Drive Train, Primary Clutch A16see57a1/5/7/9
2016 SPORTSMAN 570 EFI (A16SEA57A1/7/8/9/L7/E57A1/5/7/9) - Drive Train, Primary Clutch A16see57a1/5/7/9
2016 SPORTSMAN 570 EFI UTE HD (A16SUH57N6) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 EFI UTE MD (A16SUE57F1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 EFI UTE TRACTOR (A16SUS57C1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 EFI X2 EPS (A16SWE57A1/A7) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 EPS UTE QUAD (A16SUC57C1) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 SP (A16SHD57A9/AR/E57AS/AM) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 SP (A16SHD57A9/E57AS/AM) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 SP EPS, QUAD (A16SHC57CM) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 SP EPS, TRACTOR (A16SHS57CM) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 SP MD (A16SHE57NM) - Drive Train, Primary Clutch
2016 SPORTSMAN 570 SP TOURING (A16SJE57AB) - Drive Train, Primary Clutch
2016 SPORTSMAN TOURING 570 EFI EPS MD (A16SDA57N2/E57N2) - Drive Train, Primary Clutch A16sde57n2
2016 SPORTSMAN TOURING QUAD 570 EPS (A16SDC57C2) - Drive Train, Primary Clutch
2016 SPORTSMAN TOURING TRACTOR 570 EFI EPS (A16SDS57C2) - Drive Train, Primary Clutch
2017 570 SPORTSMAN 6X6 (A17S6E57A1) - Drive Train, Primary Clutch
2017 570 SPORTSMAN 6X6 TRACTOR (A17S6S57C1) - Drive Train, Primary Clutch
2017 570 SPORTSMAN 6X6 TRACTOR (A17S6S57C1/CM) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 EFI (A17SEA57A1/5/7/9/L7/L8/E57A1/7/9/F57A4) - Drive Train, Primary Clutch A17see57a1/7/9/F57a4
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/8/9/L7/L8/E57A1/7/9/F57A4) - Drive Train, Primary Clutch A17see57a1/7/9/F57a4
2017 SPORTSMAN 570 EFI (A17SEA57A1/7/9/L7/L8/E57A1/7/9/F57A4) - Drive Train, Primary Clutch A17see57a1/7/9/F57a4
2017 SPORTSMAN 570 EFI UTE (A17SUH57N5) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 EFI X2 EPS (A17SWE57A1) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 EPS EU (A17SEA57F1/SEE57F1/F2/FL) - Drive Train, Primary Clutch A17see57fl
2017 SPORTSMAN 570 EPS ZUG (A17SES57F1/F2/FL/SET57F1) - Drive Train, Primary Clutch A17ses57fl
2017 SPORTSMAN 570 SP (A17SHD57A9/AG/E57AS/E57AL) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 SP TOURING (A17SJE57AU) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 TOURING EPS TRACTOR (A17SDS57C2) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 TOURING EPS TRACTOR (A17SDS57C2/E2) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 TRACTOR (A17SES57C1/C2/C7/CL/E1/E2/E7/EL/SET57C1/C2/E1/E2) - Drive Train, Primary Clutch A17ses57cl/El
2017 SPORTSMAN 570 X2 EPS MD (A17SWE57N1) - Drive Train, Primary Clutch
2017 SPORTSMAN 570 X2 EPS TRACTOR (A17SWS57C1/C2/E1/E2) - Drive Train, Primary Clutch
2017 SPORTSMAN 570/450 EFI MD (A17SEA57N1/EE57N1/NL) - Drive Train, Primary Clutch A17see57nl
2017 SPORTSMAN TOURING 570 EFI EPS MD (A17SDE57N2) - Drive Train, Primary Clutch
2017 SPORTSMAN TOURING 570 EFI EPS MD (A17SDE57N2/A57N2) - Drive Train, Primary Clutch
2018 570 SPORTSMAN 6X6 (A18S6E57B1) - Drive Train, Primary Clutch
2018 570 SPORTSMAN 6X6 EURO (A18S6E57F1) - Drive Train, Primary Clutch
2018 570 SPORTSMAN 6X6 TRACTOR (A18S6S57C1/CL) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/BK/F57B8) - Drive Train, Primary Clutch A18see57b1/7/9/Bk/Sef57b4
2018 SPORTSMAN 570 EFI (A18SEA57B1/7/9/L2/L5/L7/E57B1/7/9/F57B8) - Drive Train, Primary Clutch A18see57b1/7/9/Sef57b4
2018 SPORTSMAN 570 EFI HD (A18SEF57N5) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EFI UTE (A18SUE57N5) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EFI X2 EPS (A18SWE57B1) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EPS EU (A18SEA57F1/SEE57F1/7) - Drive Train, Primary Clutch A18see57f1/F7
2018 SPORTSMAN 570 EPS EU SP (A18SHE57FS) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EPS TRACTOR (A18SES57C1/C2/C5/C7/E1/E5/E7/P57C1/T57C1/C7/E1/E7) - Drive Train, Primary Clutch A18ses57c1/C2/C5/C7/E1/E5/E7
2018 SPORTSMAN 570 EPS TRACTOR (A18SES57C1/C2/C5/C7/E1/E5/E7/T57C1/C7/E1/E7) - Drive Train, Primary Clutch A18ses57c1/C2/C5/C7/E1/E5/E7
2018 SPORTSMAN 570 EPS TRACTOR SP (A18SHS57CS/ES) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 EPS ZUG (A18SES57F1/F7/SET57F1) - Drive Train, Primary Clutch A18ses57f1/F7
2018 SPORTSMAN 570 EPS ZUG SP (A18SHS57FS) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 SP (A18SHD57B9/E57BB/E57BS) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 SP TOURING (A18SJE57BU) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 SP TOURING (A18SJE57BU/LU) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 TOURING EPS EU (A18SDA57F1/SDE57F1) - Drive Train, Primary Clutch A18sde57f1
2018 SPORTSMAN 570 TOURING EPS TRACTOR (A18SDS57C5/E5) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 TOURING EPS TRACTOR SP (A18SJS57CU) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 X2 EPS EU (A18SWE57F1) - Drive Train, Primary Clutch
2018 SPORTSMAN 570 X2 EPS TRACTOR (A18SWS57C1/C2/E2) - Drive Train, Primary Clutch
I put a red EPI sping in my stock clutch. It raised the engagement RPM. Enough that it will back up without having to hit the override, but not by much.
I like it.
