Without knowing what year models - I think it's safe to say no - the 400 is probably a 2 stroke and the 500 is probably a 4 stroke - generally the 500 will have a larger diameter crankshaft than the 400 - if you try to put the 500 clutch in the 400, it will probably not tighten on the taper properly if at all.
Tell me what year models and I can give you a list of all the vehicles the OEM clutches were used on - you might get lucky and they will be the same.
It's a 1997 scrambler 400
Yep, it'll work just fine.
SERIES 10 RGR RANGER DRIVE CLUTCH - A10RB42AA (4970937093C04)
SERIES 10 RGR RANGER DRIVE CLUTCH - A10RD50AA (4970937093C04)
SERIES 10 RGR RANGER 500 6X6 DRIVE CLUTCH - A10RF50AB (4970937093C04)
2002 ATV SCRAMBLER 400 2X4 DRIVE CLUTCH - A02BA38CA (4969936993B08)
2002 ATV SCRAMBLER 500 2X4 DRIVE CLUTCH - A02BA50AA/AB (4969976997B14)
2002 ATV SCRAMBLER 400 4X4 DRIVE CLUTCH - A02BG38CA (4974677467A14)
2002 ATV SCRAMBLER 500 4X4 DRIVE CLUTCH - A02BG50AA/AC (4970027002B09)
2002 ATV SCRAMBLER 500 4X4 FREEDOM DRIVE CLUTCH - A02BG50AA/AC (4970027002B09)
2002 ATV TRAIL BOSS DRIVE CLUTCH - A02CA32AA/AB (4969816981B13)
2002 ATV XPLORER 400 DRIVE CLUTCH - A02CG38CA (4970247024C03)
2002 ATV SPORTSMAN 400 DRIVE CLUTCH - A02CH42AA (4968536853C03)
2002 ATV SPORTSMAN 500 ALL OPTIONS DRIVE CLUTCH - A02CH50 ALL OPTIONS (4967436743C05)
2002 ATV INT'L BIG BOSS 6X6 DRIVE CLUTCH - A02CL50AA/DA (4967986798C03)
2002 ATV SPORTSMAN 6X6 DRIVE CLUTCH - A02CL50AA/DA (4967986798C03)
2001 ATV 325 MAGNUM 4X4 HDS DRIVE CLUTCH - A00CD32AA (4964026402C004)
2001 ATV MAGNUM 325 4X4 DRIVE CLUTCH - A00CD32AA (4964026402C004)
2001 ATV MAGNUM 325 4X4 MOSE DRIVE CLUTCH - A00CD32AA (4964026402C004)
2001 ATV TRAIL BOSS DRIVE CLUTCH - A01AA32AA (4963816381C002)
2001 ATV TRAIL BOSS 325 SE DRIVE CLUTCH - A01AA32AA (4963816381C002)
2001 ATV SCRAMBLER 400 2X4 DRIVE CLUTCH - A01BA38CA (4968366836B008)
2001 ATV SCRAMBLER 500 2X4 DRIVE CLUTCH - A01BA50AA (4963716371B011)
2001 ATV SCRAMBLER 500 4X4 DRIVE CLUTCH - A01BG50AA (4963766376B012)
2001 ATV 325 MAGNUM 2X4 HDS DRIVE CLUTCH - A01CB32AA (4963966396B010)
2001 ATV MAGNUM 325 2X4 DRIVE CLUTCH - A01CB32AA (4963966396B010)
2001 ATV XPLORER 400 DRIVE CLUTCH - A01CG38CA (4963916391C003)
2001 ATV SPORTSMAN 400 DRIVE CLUTCH - A01CH42AA (4964436443C001)
2001 ATV SPORTSMAN 500 DUSE HO DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV SPORTSMAN 500 RSE HO DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV WORKER 500 DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV INT'L BIG BOSS 6X6 DRIVE CLUTCH - A01CL50AA (4964586458C003)
2001 ATV SPORTSMAN 6X6 DRIVE CLUTCH - A01CL50AA (4964586458C003)
2000 ATV TRAIL BOSS DRIVE CLUTCH - A00AA32AA (4949914991C003)
2000 ATV TRAIL BOSS DRIVE CLUTCH - A00AA32AB (4960076007C003)
2000 ATV SCRAMBLER 2X4 DRIVE CLUTCH - A00BA38CA (4954835483B010)
2000 ATV SCRAMBLER 400 DRIVE CLUTCH - A00BG38CA (4954845484B014)
2000 ATV SCRAMBLER 500 DRIVE CLUTCH - A00BG50AA (4954855485B014)
What polman did was provide a list of all the models that used the same non EBS clutch as the 400 that you have. What year model 500 clutch are you looking at? The EBS clutch has a one way bearing at the bottom between the sheaves - nos EBS does not have this bearing - if you try turning the sleeve between the sheaves, if it's EBS it will turn freely one direction and lock up the other way - if it's non EBS the sleeve will turn freely both or the belt will have a loose fit - EBS belts have tension all the time.
