N:question:eek:w that my clutch alignment is good I still don't like the clutch action especially the 2600-2800 RPM before the primary begins to work. I think I am going to go with heavier weights and possibly spring in the primary. Has anyone ever done this? if so what was the out come? what spring do I use? Is this engine so whimpy on low end that it has to be set up this way. I am hoping someone can shorten my learning curve!!
Heavier weights, ligther spring(EPI maroon colored)
Look at a dalton kit for the 700 efi. A friend installed one and was very hapy with the results. Also install a new belt, washed in hot soapy water, and clean the faces of the primary clutch with a red scotchbrite pad and brake clean or starting fluid.
