Cubby, you said it well. There are probably better setups out there if someone wanted to spend the time and money to figure it out. I know a bunch of guys running HeelClicker stuff in their sleds, and if you can get them dialed in they really work. Probably the best setup out there even. But hard to dial in and a bit finicky for all around use in my experience, and that doesn't work in an ATV that is used for towing, hauling, high speed trails, gentle touring, etc. To many big variances in terrain and conditions for them to do what they do best when setup for a specific use. That said, the Polaris clutches are generally very forgiving and that is what makes them work so well in so many different uses with the same setup. Even in stock form a Sportsman does everything well.
