1 - 17 of 17 Posts
So I think I had gotten bad valves from Amazon. They were cracked and dried out on the 2 JD carts I leave outside. Anywho I had installed these Amazon valves on the 2 JD carts and the 800s beadlocks. So once I realized the valves were cracking I purchased these Colby valves because I especially didn't want to break down the beadlocks. Well I installed the first one on the 800 and seems to be a solid valve and simple install. Hardest part was making sure the entire old rubber valve came out. Cause I would have broken down the wheel if the back of that valve fell inside the tire, lol.
Hood Bumper Motor vehicle Automotive tire Font
Motor vehicle Automotive tire Hood Automotive lighting Automotive design
Discussion Starter · #2 ·
Weird I can't upload the rest of the pics. Says I'm at my 20MB limit. Never seen that before!!
Idk I think it was just the one pic. It was of just the valve before I installed it.
Motor vehicle Automotive tire Hood Automotive lighting Light
Discussion Starter · #4 ·
Ok this is just the valve. All I had to do was crop the picture and voila.
Plumbing fitting Cylinder Gun accessory Metal Auto part
Not off road approved in Colorado or Utah.
  • Haha
Reactions: bp405
Looks nice and easy!
I buy TR412 stems from the local tire shop. We have an account there and 20+ trucks so if I go in and ask for a few they normally just give them to me.
Anyways, I bought this nifty little tool that enables you to install the stem without breaking the bead. Works out on the trail. I keep one in the 570 and one in the 850
Discussion Starter · #7 ·
Hmm interesting @Mike_B !!!! I actually bought the Colby emergency valves about a year and a half ago to throw in the tire repair kit. It's funny when I first started wheeling 10yrs and 1 month ago 🤣 I ripped the valve off the stock wheels on the 800. Countless trips/rides later never has that happened to me or anyone I was riding with or came upon on the trail. But better to have it not needed than need it and not have it!
Discussion Starter · #8 ·
Reactions: FPD218
Discussion Starter · #10 ·
That sure looks like it's something that would belong in everyone's tire repair kit.
The "emergency" ones actually have a wing nut to tighten them down. One if those deals if you have it it'll never become an issue 🙄.
Reactions: FPD218
I think I like that kit. Actually I like both ideas.
I'm curious...
Does the tool kit work as easy as it looks?
I guess a little spit to lube the new stem would make installation easier lol?
I may just look into both. Keep the change kit for around the garage and carry one of those Colby valves on the trail. Never had a valve fail in the woods but it would be a deal breaker in the middle of nowhere. That Colby valve would be a quick easy solution and will fit right in the tire kit I already carry onboard.
Learn something new on here every day. (y)
Discussion Starter · #13 ·
Yeah I've done a ton of times as I currently own 3 sets, lol. But sometimes it's worth spending the extra scratch to make life a little easier. I like easy!!!!
Reactions: Heavy_GD
I'm curious...
(y)
Works pretty good, I was surprised. At home, I use RUGlyde.
In the field, whatever is handy. Water, beer, a couple drops of antifreeze from the overflow tank.
Only had to use a couple times but invaluable when needed
Yeah, got to thinking about it after the post. You could just pull the dip stick out and get a little oil on your fingers to lube the new stem... But spit would be a lot faster lol.
I don't have a oil dipstick
Gas Composite material Nickel Auto part Aluminium
1 - 17 of 17 Posts
