I recommend anyone with a two stroke to plug the oil tank and always mix the gas and oil then put in the fuel tank. I had a jet ski that had a oil tank and mixed automatically. After the oil pump went out and the engine didnt recieve any oil it caused the engine to lock up. This cost me about 2800$. I agreed with the mechanic and we plugged the oil tank line and I always pre-mixed because then you never have to worry about it you are getting oil and the correct amount mixed before injecting into the engine. So, again I completely agree with plugging line and always pre-mixing. Happy Riding.i have a quick question you guys really seem to know what your talking about so i have an 95 trail boss 2 stroke not getting oil can i just plug the oil lines and mix the gas myself and pour it in i would rather do it that way any way
I have a 1998 Polaris 300 4x4 2 stroke. I mix my gas 50:1 haven't had any problems or power loss. 10oz to 4 gallons gas. Gas Oil Mixture Ratio Calculatori have a quick question you guys really seem to know what your talking about so i have an 95 trail boss 2 stroke not getting oil can i just plug the oil lines and mix the gas myself and pour it in i would rather do it that way any way
The only time I've ever seen a two stroke oil pump fail was when it was left sitting with an oil/water mix for about 2 yrs.I recommend anyone with a two stroke to plug the oil tank and always mix the gas and oil then put in the fuel tank. I had a jet ski that had a oil tank and mixed automatically. After the oil pump went out and the engine didnt recieve any oil it caused the engine to lock up. This cost me about 2800$. I agreed with the mechanic and we plugged the oil tank line and I always pre-mixed because then you never have to worry about it you are getting oil and the correct amount mixed before injecting into the engine. So, again I completely agree with plugging line and always pre-mixing. Happy Riding.i have a quick question you guys really seem to know what your talking about so i have an 95 trail boss 2 stroke not getting oil can i just plug the oil lines and mix the gas myself and pour it in i would rather do it that way any way
:biggthumpup:figured out the issue, i diddnt clean the diaphram when i tryd cleaning the carb, put a new k&n airfilter in it and it runs great now
I put in Alan head bolts to replace the screws. Much easier to get off!!Carb question, does anyone else have problems getting those 4 float bowl screws loose, EVERYTIME I GO TO SERVICE ANY OF THE 3 carbureted bikes we have I always have trouble with at least 2 of the 4 screws, I regularly have to use a manual impact driver to get them undone and I replace them at least every other time. Any tricks y'all use to keep them from seizing?
