101 - 120 of 134 Posts
· Registered
i sent back an email but I don't know if that will ever show up so here is my answer. Found that I needed do redo the carb again and took a long straight thin nedle and went down that centre hole where the slide rod fits into and after that blew air in pipes to clean it. That did the trick as far as speed went. I do find the plugs don't like getting their feet wet so when I start having trouble with starting I simply pull the gas tank and install a fresh plug and away we go again.. Never been fond of NGK plugs as once they foul it is iffy even after cleaning they spark right again. I have switched to the E plug and find they work just as well after being cleaned. I never put the shroud over the tank back on and leave the tank unbolted I have to change plugs so often and I very rarely use the choke. Many claim high test will do the trick but these units should not have to be babied with high test gas. When it's running I love it.
dajcat
· Registered
I have a 2003 Magnum 330 that will not take the gas if the air filter is disconnected. Is this normal? It doesn't run well at all until the air box top is back on. Then it still seems to be a little sluggish but will run. I don't plan on running it with the air box off but would like to know if there is a problem lurking before I get back in the woods with it. I looked through and cleaned the carb but it didn't look dirty to start with. Problem I started with turned out to be tank stopped up at the petcock. I guess what I want to know is does this type of carb require the restriction of the air filter and box?
· Registered
Yes.
I have not ran my 325 without the airbox lid, but a freelance polaris mechanic (that I had work on my scrambler 400) mentioned one time that the 325/330's can run sluggish/weird without the airbox top on.
· Registered
The aftermarket filter will not give you a problem. The uni offers much better filtration over stock paper filter .
· Registered
The following link ( 2000 Polaris 325 MAGNUM 4X4 HDS (A00CD32FA) Carburetor - A00cd32fb | Part Shark ) is to the mikuni carb on my 325 Magnum. The parts blow up does not match up exactly to the carb that was referenced below in the sticky note from page 1. Can someone tell me what parts in the link to my carb correspond to the parts listed below?
As a test when the engine is warm and you pull the choke it should kill, or almost kill your engine. On my TB if I just touch my choke it will die. If there is no effect either the adjustment is wrong, the idle mixture is too lean, or the choke is still clogged.
Here is a Typical Mikuni Carb blow up. There are many variations but they all use the same basic design.
Parts referenced in this writeup:
#8 Needle Clip - used to adjust the needle height
#9 Needle - this is what is used to meter midrange rpm fuel
#36 Main Jet - this is what meters the high RPM fuel
#21 Idle/Pilot Jet - Meters idle RPM fuel
#32 Idle set screw - adjusts the idle RPM by setting the stop position of the slide (part #10)
#29 Idle mixture screw - used to fine tune the idle mixture
#23 Float arm - notice the small tab in the middle this is what you bend to adjust the float levels
· Registered
I have a guestion,but don't know exactly how to post it . It's about how to remove my caberator ?
It is a 2007 Hawkeye . The carberator needle valve seems to be stuck from old fuel (NEVER AGAIN) I had just changed the oil for a new season then the next morning I started to checked the oil again before going out. my crankcase was overflowing ! Anyway each time before I shut down the engine I turn off the fuel and let it run out .
How had is it to remove and clean the carberator ??
· Registered
I just put new Mikuni 34mm on both my 500s (98 and 99) and they were 30 bucks each and 20 bucks postage.
So long as I can get real Mikunis and not some Chikom knock-off for 50 bucks, I'll never rebuild a carb for these machines....ever.
Put 'em both on yesterday, took about an hour, and they started right up with a whiff of starting fluid and run better than they have since I got 'em.
Got the carbs off of Ebay.
The other thing is, at least here in AZ, we have this alcohol contaminated fuel for the eco-assholes to crow about...it does not lend itself to sitting with carburated vehicles. So I have to find a place that sells non-ethanol gasoline because I tend to use mine in summer and hunting season and then sit for months hooked up to a battery tender. I know I can use Sta-Bil but buying uncontaminated gas is probably easier.
D.
· Registered
I can only relate how we did ours. Take the seat off. Unfasten the airbox nuts or bolts, remove the front two hoses that come to the airbox. Loosen the hose clamp for the rubber union that goes between the airbox and the carb.
Turn off the fuel at the shut off valve. On the Sportsman there were two very different assemblies for securing the carb to the frame. One had a wire-looking thing and two little tabs that screwed into the rear of the carb, the other had a real metal plate. Remove whichever you have.
On the 34mm Mikuni there are two vent ports at the upper rear of the carb. Remove those hoses and they should T to one hose and just be stuck in a hole on the frame. They're just vents.
Two fuel lines need to be disconnected. Don't mix them up. One will drain some fuel, the one on the left, so have something to catch the fuel.
You can work around it but there's a drive belt housing fresh air intake pipe that I had to removed because I need the space to remove the cables. It's kind of a PITA. But it can be done. You might have to loosen the fasteners that hold the fuel tank covering plastic to get the hose out.
The Mikuni 34mm has a plastic cover which protects the cable linkage. Remove the screws and use something to hold the butterfly open like you're accelerating, don't use the accelerator. A hook tool will help route the cable around the linkage boss. There should be a small aluminum or brass cable end that sits in the linkage, a cable terminus. Before you hook it out of there, make sure you have a rag stuck in the hole where the belt drive fresh air intake went! You don't want to drop that little mofo down into that hole because it's not magnetic and you won't be able to get it out! You'll have to take the whole belt drive housing apart to get to it!
once you have the accelerator cable disconnected from the linkage and thread the boss out of the carb, you have to contend with the choke cable.
This was the worst part. I had to go find a chinese end wrench and grind parts of it away to be able to turn the brass fitting where the choke cable goes into the carb. Once it was loose the return spring and cable terminus just come right out. It's one of those 1/8th turn at a time deals, there's even a cut out on the Mikuni to allow a wrench to get on there.
Not sure what carb you have but this is what we did and I'm glad I wrote it down while it was still fresh in my mind from yesterday.
The last part is loosening the clamp that holds the output side of the carb to the neck which is attached to the engine. Then slide the carb back and off and "Bob's your Uncle".
D.
· Registered
Just about going nuts here! Help.
I have recently rebuilt my 2005 Sportsman 700 and redid the carb as well, all stock.
I can get the engine to start and run but need choke and to feather throttle. Runs nice however high rpm when I do this. If I let off the throttle at all it stalls. If while revving push in the choke it backfires very harshly out the exhaust and then stalls. My first thoughts were pilot screw circuit blocked, so apart the carb came and clean again making sure that the idle circuit was spotless. Float height checked. Adjusted pilot screw to 2.5 turns out from lightly seated and in went the carb. Well nothing changed to how it ran. It runs the same with air box on or off. Checked exhaust pipe and had installed new donuts too. Idle screw not turned in very much at all as it appeared not to have any effect right now anyhow.
What am I missing?
· Registered
Update: 11-19-2010 added some stuff..
This list should go for almost all ATV/motorcycle carbs. CV or mechanical. I tried to list them by frequency
1) Old fuel - this is the number one cause of carburetor problems. as it sits it dries out and varnishes the small ports/orifices in the bowl. All these problems can be cleaned with carb cleaner, air compressor , fine bristle brush, and a thin brass wire.
2) Clogged idle jet - the orafice is small in this jet and it is the first to get clogged with tiny varnish particles and/or dirt.
Symptoms- poor idle or no idle, you may need to feather the choke to keep the engine running at idle.
Fix - See carb cleaning section below
Prevent - install inline fuel filter and always store machine with a full tank of gas. Stabil can help but will not totally prevent the issue.
3) Clogged main jet - This will only happen with extreme dirt and varnish. more then likely your idle jet will be clogged also.
Symptoms - machine will not rev has no power, will stall when the throttle is opened.
fix - See carb cleaning section
prevent - install inline fuel filter and always store machine with a full tank of gas. Stabil can help but will not totally prevent the issue.
4) Fuel over flowing from the bowl - this is caused by a bad float needle or varnish/dirt preventing the float needle from seating, or the float is out of adjustment.
symptoms - worst case is fuel continually flowing from the carb into your engine or airbox or out the overflow. This can also be show up as a very rich running engine, or slow drip from overflow when engine is running. The engine will stumble and stall, running rich and choking itself out. Spark plug will be coated with black soot.
Fix - see carb cleaning, additionally, check the adjustment of the float arm to make sure it is perfectly parallel to the bowl gasket seat. If not you need to bend the little brass tang on the float arm until it is resting parallel when the carb is held upside down.
5) fuel flow problems - Fuel not properly flowing into the carb, caused by clogged fuel filter, clogged petcock filter, kinked hose, clogged float needle/seat, clogged breather cap (although this one will run longer before dieing)
symptom - machine runs for a few seconds up to a minute or two then sputters and dies. Worst case the engine will not run at all (no gas in carb)
Fix- it's best to remove and clean the tank with water and detergent, remove and clean the petcock, check for kinks in the fuel line replace if there are any problems, replace the fuel filter. Check the flow by filling the tank and opening the petcock holding the carb end of the fuel line over a pan. Fuel should pour ot at a good rate. Then reconnect the carb and remove the drain plug from the bottom of the bowl. Hold a pan under your carb and turn on the fuel. It should flow at about the same rate out of the bowl.
6) Choke clogged out out of adjustment - varnish is clogging the choke orafice in the bowl, or the choke cable is not opening the choke valve properly.
symptom - engine will start ok when it is warm but when it is cold out (50 degrees or less) it will take a long time to start, or not start at all.
fix - see carb cleaning section, additionally adjust your choke cable so there is no more then about 1/8" of play
7) Vent Lines clogged/kinked - The vent lines on the carb are pretty important when it comes to keeping excess fuel out of the intake.
Symptom - every time you hit a hard bump your engine boggs/stumbles/or cuts out.
Fix - clean/replace the vent lines and drain lines on the carb/bowl. Make sure they vent tubes are routed to a place high up around the snorkel for the carb. Also make sure they are not kinked or close to the exhaust. The drain lines (usually 2 going to a T to one) from the bowl are routed so gas will drip on the ground and not your engine/transmission. They need to be clear and free flowing. Also it is good to check the float level to make sure it is not set too high.
Carburetor Basics
As you can see most of these problem come from old fuel and varnish caused by old fuel. One needs to simply understand the basics of a carburetor to be able to figure out what is going on. It's sole purpose is to properly mix the right ratio of fuel to air at any RPM range. There are basically 3 circuits that allow for this.
-The first one is the idle circuit. It consists of an idle jet and an idle mixture screw (or air mixture on some models). The stock setup of most idle circuits (98%) is to turn the screw in all the way. Not too hard or you will damage the screw. Then back the screw out 1 1/2 turns. This setting should get you in the ballpark enough for the engine to idle. You then need to adjust the idle down and re-adjust the idle screw until you attain the best idle. You need to listen to the engine, you will be able to hear when the idle mixture gets better or worse. This cicuit will effect the idle mixture with a little overlap into mid range. So from closed throttle to cracked throttle. If your engine stalls a lot when you close the throttle you need to suspect the idle circuit.
-The next circuit is the main - This circuit actually has two inherent circuits the first one controls mid range throttle/RPM. The second controls Wide open throttle. It does this with the use of an adjustable needle in the slide of the carb that varies the size of the opening in the main jet circuit. In the racing world there are infinite setups/possibilities here but for home use just understand that the needle position controls everything from cracking the throttle to about 5/8 throttle. After this the main jet takes over and all fuel flow is metered by it. If you have a mid range stumble check your needle position. If your engine doesn't want to pull at WOT then check your main jet. if both are problem them your main jet is way off.
-Cold start/Choke circuit - just as the name implies there is usually some form of fuel bypass valve that allows additional fuel to be drawn directly from the bowl into the intake stream. This allows a cold engine to start on cold days, when a much richer mixture is required. It's usually controlled by a manual lever either on the carb body or through a cable connection.
These three circuits work together with an intricate network of small tubes that siphon fuel from the bowl in various ways. Understanding this will help to pinpoint issues while you are working with your carb.
Carb Cleaning and other misc tips----
Carburetor should be removed form the machine.
Start by first setting up a clean towel or large rag to lay your parts out on. You need to keep these tiny parts clean. Light color works best to provide high contrast for the tiny screws and parts. I've used paper towels and in a pinch on the trail I took off my white under shirt to fix a friends bike. Proper preparation will make this job so much easier. Any carb cleaner spray will work fine, have the finest nozzle you can for your air compressor. When blowing off parts hold on Tight!! you do not want your tiny jet flying across the garage at Mach 2!!
take the bowl off and remove the idle(low speed) jet. Then blow carb cleaner directly into the hole where the idle jet came from you should see it coome out of a few tiny ports in the engine side of the carb. Immediately after blowing carb cleaner through take an air compressor and blow directly into the same low speed jet hole. You should repeat this a few times each time looking at the flow coming through the ports. Then take your low speed jet and look real close at the openings they should be round and perfectly clear. Take some carb clean and blow through each of the holes in the jet then use the compressor and blow it off (hold onto that thing tight so you don't blow it across your garage... been there done that!!). Most of the time idle problems lie in this jet. Next remove the idle mixture screw and blow through it with carb cleaner and air. When re-assembling it turn it in all the way and then out 1 1/2 turns (don't tighten it too hard!! or it will damage the screw and the seat).The next thing you need to do is remove the float by pulling the pin that slides into the carb body. Be careful when removing this there is a tiny spring clip that holds the needle to the float arm don't lose it. Clean the mating surfaces of the needle and the needle seat. next check your needle to make sure the spring inside it moves freely. If it does not spray it with carb cleaner and work it in and out with your fingers this will usually clean it out and allow it to flex again. Then reinstall the parts and check your float level. Stock setup on most mikuni carbs is the float tab set parallel with the bowl flange. So when you hold the carb upside down your float tab (the brass lever the floats use to close the needle) should be perfectly parallel with the flat surface that the float bowl mates to. if it is not parallel then take a small screw driver and adjust it by bending the brass tab until the float arm is parallel. Now remove the main jet and spray it with carb cleaner, again viewing the hole to make sure it is perfectly clean and round. In the worst cases I use a piece of fine brass or copper wire to run through the holes to clear them out, or just the bristle of your brush. Now finally before you put the bowl back on take your brush and clean out all the gunk that is dried in there. If it is heavily varnished spray it down it carb cleaner and allow it to dry and it will rub right off like a powder. The most important thing is an eye for detail blow through all the small holes that you see and look for the carb cleaner to flow through freely. Not only will it clean your carb it will also give you a good understanding of how this seemingly complex peice of equipment is very basic and easy to understand.
Choke Adjustment----
Hmmm its easier to show someone then try to explain in text but let's see if I can get it close. This is the best way I found.
-Start with the adjuster screwed in almost the whole way before you assemble the brass slide valve back in the carb. The carb should be installed already before you start unless you cannot access the choke when the carb is installed
- now insert the valve back in the carb and tighten in down, not too much just snug.
- this is where it gets a little tricky. With one hand on the choke lever and the other on the choke adjuster start to spin the adjuster out slowly. While doing this the other hand should be working the choke lever to feel the amount of slack left in the cable. You should be able to feel when the choke cable starts to raise the choke valve. This can be tricky if your choke cable has a lot of drag. If so you should think about oiling the cable. The choke valve spring should offer enough resistance to feel when the cable picks it up..
- keep working the adjuster until you feel about 1/8" of slack then tighten the adjuster lock nut.
I hope that all makes sense I was writing this between work phone calls so it may seem a little chaotic....
Cheers..
Rusty
Nice write up , thanks!
· Registered
This might not be common, but wanted to share..
After riding for about 1 hour -- 2006 sportsman 500 HO, suddenly did not want to run when pressing the throttle. It would start and idle just fine, but if pressing the throttle, it would bog down and die. That was the end of that days ride.
I had just rebuilt the carb about 2 weeks before, so I figured that I did something wrong or else got some fresh dirt in there. I had also replaced the inline fuel filter, so it was not making sense. I pulled carb off expecting to find dirt in the main jet. It was perfectly clean and bowl did not have any trash in it. When I pulled the top off the carb with the rubber boot and spring, the needle jet stayed in the carb ! -- The clip was down in the throttle slide. The clip looked perfectly normal, so I put it back on the needle valve and it nicely clicked on. :spank: -- but, when I strarted spinning the clip on the needle valve, there were some positons that it could just fall right off. Upon closer inspection with a magnifying glass, the very small indentation on where the clip went has been worn down and would allow the clip to come off in some rotational positions. Short-term fix was to move down one notch. Long term fix is to replace the needle valve.
Talk about searching for a needle in a haystack ( or carb in this case ).
Anyway - wanted to share and hope it helps someone else -- closely inspect the clip positions on the needle valve and ensure that the clip cant come back off.
· Registered
Yes you can unhook the pump and plug the lines.
Yes you can mix your own fuel and oil in a gas can and put it in your self.
I have a 1989 250 boss and i do that on mine...
i have a quick question you guys really seem to know what your talking about so i have an 95 trail boss 2 stroke not getting oil can i just plug the oil lines and mix the gas myself and pour it in i would rather do it that way any way
· Registered
Did you find a replacement carb?
Just checking to see if you found a suitable replacement carb? I have a 96 magnum 425 and might need a carb as well.
Thx
Victor
Doe anybody have any swap or replacement carb info?
Dealer wants $481.
I've got broken parts in my carb and would rather buy a new and repair mi e for a spare.
From searching i've only found this style carb on polaris and maybe triumph.
The Mikuni TM series I think look similar but havent seen one up close to see linkage etc..
Factory is 34mm I think for my 95 magnum 425cc, I wouldnt mind stepping up to a 36mm either.
· Registered
My latest experience was that as the quad sat since early this spring, the pump must have lost it's prime or dried out. After replacing the starter and bendix (unrelated issue) I couldn't get it to start. I had spark. I didn't see any gas in the line to the carb with the filter. A little suction on it and I had gas in the line. Hooked it back up and presto, smooth running again.
· Registered
2005 500HO
carb over fueling, remove carb, clean, install oem carb kit, r/r fuel filter. no more fuel leaking from bowl but have fuel spraying out of the Air jet on front of the carb (intake side). Did i miss something when i reassembled the carb, is there any adjustments that are needed on the jets for this make of carb.
· Registered
You did check and re-set float level? It ALWAYS needs checking when you fit new parts, OEM or aftermarket
The air jets will be on air box side of carb or under diaphragm on most CV carbs,
Saying' intake side' doesn't actually tell anyone anything as carb is on intake side of engine and direction of airflow is from air box to engine (mostly).
Due to reverse airflow at idle (valve overlap at TDC) some 'spitting' is inevitable, but, it is usually accounted for when entire air system is in place (from filter inlet right through to valve head) If fuel level in float bowl is too high (float height too low) the pulses will pressurise float bowl and 'blow' fuel out of lowest points. It can get bad if various vent holes and hoses are not clear
