took the crank out of my 04.5 700 was looking at part # the cases are the same as the 05 800 just was wondering what would you have to change cam pushrods and maybe remap ecu ,injector # are the same, a crank on evil bay is 750 or a kit for an 800 with new crank, cylinder and gaskets is 1100 just a thought thanks in advance for input
All you need to change is the crank, balance shaft & pistons. The bore is the same as the 700, just the stroke is different thus the different piston pin location. I can't tell you about the remap of ECM as mine is carb.
