1 - 12 of 12 Posts
Coil Spacers vs HD Springs?
Over the long term, would the coils be the better investment?
I want to do all 4 corners, the way it dives in corners is starting to annoy me.
I have my eye on High Lifters HD springs. Will these add a little lift to it?
https://www.highlifter.com/p-847-high-lifter-front-rear-lift-springs-for-polaris-sportsman-400500570600700800-see-apps.aspx
https://www.highlifter.com/p-3063-spring-adapter-kit-for-2011-2014-polaris-models.aspx
Thankfully, HL is the only ones that offer rears, as a spring adapter kit is needed for 2011 to present Classic models, which they also have. :)
Thanks,
Will
2012 Sportsman 400HO.
I do not think they will provide actual lift. Now they made provide slight lift over the stock springs if the stocks have sagged or weakened with age and use.
Just go for the springs!!!
I felt exactly the same before changing out mine ! They are now great. Only complaint is I would still like a bit stiffer out back for two up riding. I am hoping rubber Polaris spacers will do this for me. I have said it many times the instal of these springs is one of the best things I did to my machine!!
Discussion Starter · #7 ·
Thank you!! Will do them next!!
Thanks,
Will
I did HD springs in the rear and the Polaris preload adjusters in the front as I wanted a stiffer suspenion in the rear and wanted to retain the stock ride in the front for trail riding and have the ability to stiffen it up in the front if I wanted, especially when I have the plow on it.
do u have a link to the rubber polaris spacers?
Polaris Sportsman Coil Spring Spacer 2872655 | eBay
im with cw, springs are one of the more important mods to my bike. i wouldnt call it lift more like a rise, a lift increases suspension travel and the hl or epi springs just have a higher spring rate. but the important factor is it improves ground clearence.
with the hl on the front springs i dont understand what that collar/spring retainer is? on mine (epi's) i have a flat washer that the spring sits on. that washer is what the oems sat on.
thanx.
1 - 12 of 12 Posts
