1 - 2 of 2 Posts
I'm new to atving and wonder if i should change all my lubricants ,,first of all how often should one change the coolant on his bike ? my over flow bottle is low ,so I'm just wondering if I should top it off or do the complete job and change it all now?
The fastest way to get a good reply is to state the make model and year of your atv. I will give you a general answer.
Oil is yearly or every 25 hrs
Front and rear Differential about every 50 hrs. Depending on your riding conditions.
Its quite normal for the overflow bottle to be a little bit low. You can top it off, but you may find that it will soon return to the same level. If you bought this ATV used, it is a good idea to just change them all asap. Good luck!
1 - 2 of 2 Posts
