yes diesel engines use nitrate as a anti cavitation additive....
The cavitation issue in a diesel is the cause for the proper type of coolant to be used. In many times with the proper additive, called SCA (supplemental coolant additive). Traditional green ethylene glycol antifreeze required the SCA to help prevent and/or protect from cavitation. Ford/Fleetguard type uses nitrites in combination with molybdate to form a sort of corrosion layer, so I've read, which builds up on the coolant side of the cylinder liner. When the vapor bubbles form, they eat the built up corrosion layer and not the metal of the liner. The other type of SCA is the penray type, which is mostly nitrite.
