1 - 2 of 2 Posts
doese any one know what temperature the coling fan should kick in on 330 atp. at the moment bike is getting to 65 deg on on the inlet side of the oil cooler with no sign of fan kicking in.
Depends on your temp sensor......
Fan should come on about normal operation 195 to 215 degrees.Depends mostly on what temp sensor you have,you may want to make sure the systems full ,no air in the system...check your fuses, then check your Coolant temp sensor and your cooling fan itself...put a jumper wire to both sides of the Raditor temp sensor, should turn on...and check thermostat operations also....make sure the coolant is cycling threw the system...MUDDIE49
1 - 2 of 2 Posts
