I just got a sportsman 400 with a leaky mechanical water pump seal. Started pulling plastic, couple questions for you.
1) do you have to pull the exhaust off? I believe this seal is on the right side of the motor so is this in the way?
2) do you have to pull the flywheel off. Have a friend who says its behind the flywheel, which doesnt make sense to me.. If you do, do you need a special tool for this??
3) where did you get your new parts? Could someone give me a quick list of what all i will need? I have heard i need a new oil seal also. any help would be greatly appreciated . would love a list with part numbers
thank you all in advance
