Hi All,
I've had the bike for almost 5 years, and it has served me fairly well, however there are a couple things I've noticed recently. Bike has 4000km. Mods done are a 2 inch lift, SS212 Wheels and GBC Spartacus 27 inch radial tires.
1) Clicking on my rear left side. The sound increases as speed increases. I don't hear the sound if I'm driving on snow. I assume this is probably a rear CV Joint/Axle? Is there an easy way to check to see exactly what is damaged, or do I need to order a specific part from Polaris? On that note, I assume I should also change the other side while I'm at it?
2) Almost no top end. Right to the bar, this bike runs 62mph on the speedo and won't go any higher. I believe the bike pulls about 6800RPM at this speed. Clutches and belt seem good. Could it just be this is how this bike should run with those tires/wheels/lift?
Thanks in advance
Thanks in advance
