anyone know what threads and size of crankshaft nut that holds flywheel on a 09 sp500 would like to pick it up from napa instead of waiting a weak and a half for part to come in
Discussion Starter #2
anyone kno threads on crankshaft?????
The flywheel nut should be a 16mm. The lower cam chain sprocket split nut behind the flywheel is a special 28mm slotted nut.
Hope this helps.
Mark
thnx for the reply any idea what ID and thread count are??? for the outside flywheel nut not the slotted nut
Try M10x1.5.... .. . maybe. Let me check.
Mark
i dont think so 7/8 took it off but i think its a metric nut
