Congrats to crazyflyboy30s and Am3ric4nGI for winning June and July!
crazyflyboy30
The biggest thing is that I have cut it into and added frame to make the Wheelbase 63 1/2" .
Most of the other Modifying was also to add to the hill climbing ability or performs and durability.
Relocate battery to bottom of frame.
Cecco Racing Front Gear Case Cover.
Hunterworks Rolls in Secondary.
EPI Pink Sring in Secondary
NGK Spark Plugs.
R2C Airfilter.
Gates Carbon C12 Belt.
Machined out A arms and put in ball bearings
196 Ball Bearings in the Suspension.
Steering Bushing replaced with Yamaha Grizzly Bushing.
Custom frame braces front and rear.
1/4 Steel Skid Plates.
Added Magnets to the fill plugs.
No Sway Bar.
Fluidyne Racing Radiator
FPS11-14SCRM850.
Fan Upgrade 1900 CFM.
Fan on a Switch.
3000 lb. Super Winch.
HD Hand Guards.
Polaris OEM LED light upgrade with HALOS.
HD Tie Rods.
Tires 27x11x14 XTR on all 4 with 4 OEM rear rims.
Highlifer Rear Rake A Arms.
Race Driven Severe Duty Bakes.
Kryptonite Wheel Bearings.
Autometer Oil Pressure Gauge .
Autometer AFR Gauge.
RJWC Exhaust with Custom Tuner.
Quantum Fuel Pump.
RMSTATOR 65 amp.
All U Joints Upgrade Spicer
Front Gear Case Upgrade with new 2022 and Aluminum Roller Cage.
Am3ric4nGI
crazyflyboy30
NGK Spark Plugs.
R2C Airfilter.
No Sway Bar.
FPS11-14SCRM850.
Fan on a Switch.
HD Hand Guards.
HD Tie Rods.
Quantum Fuel Pump.
RMSTATOR 65 amp.
Am3ric4nGI
