Idle to fast, belt out of adjustment? Welcome aboard!
Have you just replaced the Belt? Having a belt that is to tight will cause the machine to creep forward at idle. The one way bearing on the primary clutch could be bad or the fiber washers on each side of the bearing could be gone. You could have a broken motor mount. This is a list of some things to check.
Good Luck!
