I have a 03 600 sportsman and when I go in reverse and turn the bars to the right the engine dies. It always starts right back up but what gives? Is there somthing that is pinching off and causing it to stall? All the lines seem to be clear when I poke around looking for the problem. I have also had it cut off when I am in low and climbing a hill without giving it alot of gas. Any suggestions. Thanks in advance.
Welcome!! Not sure, but if you have your key on anything that hangs down(key fob, etc.), that could be the culprit.
Ditto to what racer37 said...I had a keychain with some little thermometer or something on the ring and on a few occassions, when turning to the right, it would catch just right on the plastic and would kill the bike.
Look there first, that would be the easy fix!
Jason
Thanks alot for the reply's. Not sure why but I took my key fob off and it WORKED. Now to fix the dang squeak in the front end.
