I hate to bother. i am new here and in doing research on this site i am convinced the ECM is fried. i have 2004 sprortsman 400 with the dead ECM issue. Polaris #4011110. I have done the checks using information found posted and have much less than battery voltage on the orange wires comming out with 12+ volts in on the red wires so convinced it is bad. this part is expensive and evidently on back order right now. I know i can jump 12v to the start switch and run the atv but i assume without the ECM there will be no charging. Is there a way to bypass the ECM using just an aftermarket voltage rectifier/regulator so i have a charging circuit.
Anyone with help it is greatly appreciated.
