1 - 2 of 2 Posts
I have a 2003 sportsman 700 twin with the upgraded kokasun ignition.Recently I was plowing the driveway and it backfired and shut down after backing up for the next pass.I replaced both 20 amp breakers under the front cowling,checked the solenoid wires,and made sure the battery was fully charged but it still does nothing.No lights,no dash read out,nothing.I checked the plug at the kill switch and all seemed tight.It will crank over if I jump out the solenoid but it will not fire.I am desperate to repair this machine because I am disabled and it is my only means of snow removal and my main means of transportation around the property.Any help will be greatly appreciated. p.s. Is there a third circuit breaker I'm not seeing that is located somewhere else other than under the front cowl?
Welcome to the board!
1 - 2 of 2 Posts
