2018 850SP. 2" lift. New GP bushings all around. Horrible wobble begins at 40ish. Stops when not going straight.
Sent from my SM-G960U using Tapatalk
Used to get that on my 06 dodge mega cab. Scary stuff2018 850SP. 2" lift. New GP bushings all around. Horrible wobble begins at 40ish. Stops when not going straight.
Toe was insanely off. My friend eye balled it when he did the tie rods (before I bought it). Front of the tire measured 41". Rear measured 44". I believe I'm currently at 1/4" difference now.What have you checked? Alignment / camber/caster / tie rod ends / steering linkage from the handlebars to the power steering spline / etc. . You may even need to go as far as getting the wheels balanced. No common on ATV's but when you are at a loss in a situation like that it is another rabbit hole last ditch effort option.
All good. Just trying to give you pointers on what to possibly look for. You may have already looked at most of those items but I wasn't sure.Toe was insanely off. My friend eye balled it when he did the tie rods (before I bought it). Front of the tire measured 41". Rear measured 44". I believe I'm currently at 1/4" difference now.
I would've updated the post faster if I didn't get a phone call.
Thanks. Some of those things I wouldn't have considered. The death wobble is gone, even when going straight! I hit 66.. small inconsistent shaking at random speeds, so I might go for a wheel balance, too.All good. Just trying to give you pointers on what to possibly look for. You may have already looked at most of those items but I wasn't sure.
Yes, it’s true Polaris power steering is a little too powerful at higher speeds, I finally got used to it.Thanks. Some of those things I wouldn't have considered. The death wobble is gone, even when going straight! I hit 66.. small inconsistent shaking at random speeds, so I might go for a wheel balance, too.
The guy before me had it for a week. I didn't ride it before taking it apart to address the one way bearing. That's when I changed all bushings, etc. The problematic steering coupler is brand new, and I also cross drilled and bolted it to the shaft. The front end is tighter than a frog's asshole, so I don't know if that causes too much feedback which allows one to feel EVERYTHING.
