Has anyone used the new OTB Check Tech tool? It's used like digital wrench in regards to reading/clearing fault codes, monitoring engine/sensor data, etc. Looks pretty slick.
I had started out looking for a simple TPS cable used for setting the voltage with a DMM and stumbled onto this. I figure it'll work fine for that as well as monitoring the rest of the sensor performance in the future.
It's on sale this month, so ordered a kit to play around with. I'll do a full writeup with screenshots, etc once it gets here if people are interested.
Video of it in use:
PS - I'm also planning on getting the Dobeck AFR+ Gen4 fuel controller soon, so I'll share those experiences as well. I already have wideband monitoring capability, so first up will be obtaining baseline measurements. Then I'll move onto an aftermarket exhaust of some sort..
Your vid isn't working... Hmmm now it is..
I just ordered a couple of things from OTB. The sale price for the Check tool is pretty good. Please let us know how it goes when you get it.
Will do. I have an idle miss issue that I'm trying to track down, so hoping this will help me key in on where the issue is..
Have a 2017 570 Sportsman sp and how do I get the codes?
Refer to your 'owners manual', it will explain. If you don't have an owners manual, here's a link to one online.
