Hey guys sorry for beating a dead horse here i’ve been reading other posts with the same problem i can’t seem to fix mine
2003 predator 500
just cleaned carbs
new air filter
new battery
new spark plug
fresh oil change
adjusted cable slack
quad still seems to die when i let in the choke after it’s warmed up. any suggestions. thank you
to the forum
  • Love
Reactions: Dusty2xx
Can you hold the idle with the throttle? If yes simply adjust the idle speed screw - if no (won't idle without choke) the carb needs serviced, the idle circuit is clogged.
