Dies when hitting throttle
722 views 7 replies 4 participants last post by  LATEBURD HERE 2 HELP
04 magnum 4x4 has been dying for the last 1.5 years when I give any throttle whatsoever. I have installed a new carburetor, used cdi box, multiple fuel filters, fuel pump, new intake boot, new fuel lines, adjusted clip on needle, messed with idle screw, quadruple checked any hoses and seals, checked the ETC. has consistent spark. Also has great compression. I am lost as what could be the issue. Any help would be greatly appreciated
#7 ·
That’s the point we are trying to make. Is it a new OEM carb or is it a junk Chinese replacement carb from Amazon . Because if it is it is the carb that is most likely the problem. They do not come jetted and tuned for your exact application and most times no jets or needles are available to tune them.
